Kiev 35A
Kiev 35A
Has anyone been inside a Kiev 35A? I have one that jammed many years ago. Today decided to open it for a peek inside. Maybe it can be brought back to life? If not, at least something may be learned before sending it to the junk box.
So far, I managed to take the top off and assemble it back, as a first exercise. Harder than it looks, because there is a flash sensor pin must be just inserted in the hot shoe for the top to fit.
This is how the Kiev 35A looks with the top off.
As I have no idea of the mechanisms and could find no diagram or coherent repair instructions, my plan was to disassemble, look and learn. Am open to suggestions!
In order to look at the film transport, I believe that I should take off the disc of the film counter. The assembly seems to be fixed by the screw pointed by the green arrow. It is very tight and did not want to force it. Maybe it is not even a screw but an axis (?). Should I take out the key around that screw? What tool would be used for that?
Thanks for any comment!
Re: Kiev 35A
Those are e-type retaining ring, there are dedicated removers
But i have used a tiny screw driver for such purpose
https://www.wikihow.com/Remove-E-Clips
Re: Kiev 35A
Looks remarkably similar to my Minox 35GT - maybe have a look at some of the online resources for those cameras? I found a few resources on Flickr. The flash switch is exactly the same, actually not that hard to push into place. IIRC I just used a piece of card to slip it into place while putting on the cover.
Re: Kiev 35A
Re: Kiev 35A
Thanks for these resources. I found a repair manual for the Minox EL, where there are some diagrams, and plan to go on with the exploration soon. Indeed it is supposedly a copy of the Minox GT.
Yes, I did it with a thin plastic rod. Will be easier next time.
