Photo upload code testing
'The F Stops Here' - What's New, plus comments and questions about the forums.
The developer is trying to figure out why the tool isn't work.
The "Photo upload tool" still isn't working, even though it is displayed to the right.
If you use it, you'll get a ton of code that is being used to debug.
Re: Photo upload code testing
The code is still "under review."
ImageShack has made some changes to its account structure, and I need to see if it affected the photo upload tool.
There is some kind of disconnect on the API. I can write a very simple upload using the API key, and it works.
But a PHP solution doesn't work. It's the correct way to do it, because it doesn't expose the API key.
In other words, still working on it ...
