Noob questions, why north? And reflector you mean a panel which reflects the light coming from the window?
Watches.
Re: Watches.
Re: Watches.
Alex, in the northern hemisphere a north facing window will always give you soft sky-light, consistent throughout the day. A south facing window will generally give direct sunlight on a cloudless day, of a variable nature. Old photographic portrait studios were usually located so that there was a north facing roof light providing the illumination.alexvaras wrote: ↑Sat Sep 14, 2019 8:12 amNoob questions, why north? And reflector you mean a panel which reflects the light coming from the window?
Re: Watches.
Yes, I was thinking so... I have a closed balcony facing north, all windowed the upper part, I did already one portrait there and yes, it's soft the difference between illumined side and the shaded side, let's see how it goes now that light will be lower than usual.
Thank you, Graham
Thank you, Graham
Re: Watches.
In my part of the world that doesn't matter, the declination of the sun is minimal
However, that explains a lot since most of the studios had windows facing N or S but rarely E or W
Thanks
Thanks
GrahamS wrote: ↑Sat Sep 14, 2019 9:06 amAlex, in the northern hemisphere a north facing window will always give you soft sky-light, consistent throughout the day. A south facing window will generally give direct sunlight on a cloudless day, of a variable nature. Old photographic portrait studios were usually located so that there was a north facing roof light providing the illumination.
Re: Watches.
Unfortunately, my place faces southeast, so the other side is northwest. I have to pick the right time of day to get the softer light.
Re: Watches.
"It's all in the light!"
