CoronaVirus Pandemonium
Re: CoronaVirus Pandemonium
Where I live in NC, the number of cases is very low and things seem contained
Yet the governor is on a nice power trip....
Anyhoo, in an exercise of futility I decided to make 35mm adapter for my Ricohflex. Designed it and 3D-printed
Will test it soon
ImageRicohflex-35mm adapter
What a project! Did it work? I am concerned about the durability of 3d-printed plastic parts that have to bear some stress.
Julio1fer wrote:
Fri Jun 05, 2020 7:03 pm
I've got a printed grip for my CL that feels good and sturdy. But it does make one wonder when viewing the layers that run through all the stress points.
Yes, the adapter worked fine in the Richoflex; however the shutter got out of whack (again) and most of the pictures were either overexposed or had dark spots from the shutter not closing properly
It is also very weird to shoot a TLR sideways, but that was fun
The parts are fine, I printed them with 5 solid layers on top and bottom and 8 perimeters; plus the infill was using a star which is the strongest
PLA is fine for the amounts of stress we subject it to, I have printed parts for the car, a friend's boat and some others which have held up well
For high strength you can always use ABS
Durability depends on the material, print technique, layer height, infill, etc etc etc
for the grip (this one https://www.thingiverse.com/thing:597022) the stress is minimal and can be printerd in PLA or ABS at about 0.2mm with 5 perimeters or more and should be fine
PFMcFarland wrote:
Sat Jun 06, 2020 5:08 pm
Another crazy idea....
I was using and old Pentax CopyPod to dogitalize negatives using my DSLR but them i realized I could use one of the enlargers to do the same with more precision
In the old times I had a Nikon Repro-Copy outfit like the one shown HERE with the particle board base/carrying case
I liked the idea of having prongs to hold the camera horizontal with the image plane and decided to make one to fit my camera and my old enlarger (Bogen 22B) The enlarger had a screw (1/4"-20) to mount the head, and 2 holes to make the enlarger head horizontal so it was easy to attach small screws (4.5mm head) to do the same. I have ordered shoulder screws which should be perfect for v2.
The prongs have a bit of tolerance and I have found it can be used in most Pentax cameras and it should be easy to modify for any brand of camera/enlarger
The finish at the top is not very good, but that was me experimenting
The file for 3D printing is here: https://www.thingiverse.com/thing:4440710
Front
Back
Camera Mounted
I would say it does the job pretty well :)
Congrats!
titrisol wrote:
Sat Jun 06, 2020 8:23 pm
I do believe that's the file he used. Truth be told, I don't put a lot of stress on it when holding the camera, it just creates a place for my fingers to rest. BTW, I found out there is a roll of film in it I forgot was loaded. Will have to check my log to see what it is.
Good use of a retired enlarger. I'd been thinking of getting a repro stand, but now I just might convert my $10 Bogen 22a Special.
PFMcFarland wrote:
Sun Jun 21, 2020 3:33 pm
If you want me to make one for your camera let me know, I'll be glad to
Wow, that last post of mine was from June! I have been away from here way too long.
Don't know as I'm really liking the grip I have, Pablo, or if any other one would work for me either. I'm thinking of just using a wrist strap from now on. Only two thirds through that roll of film too (Ilford Delta 100).
