Ansco Super Memar
Re: Ansco Super Memar
Make sure it moves freely by pushing with a toothpick
If it's not moving freely you might need to add some oil (a micro drop) in the fulcrum until it does
PFMcFarland wrote: ↑
Sun Feb 21, 2021 11:57 pm
I think your main issue, Scott, is the B Lever is not swinging into position to block the Drive (under the Cocking Gear) and the Cocking Rack. Could be something to do with the spring that puts pressure on the B Lever, or the B Lever could be dragging on the support bar. I'm going with not enough tension in the spring. It can be adjusted without removing the B Lever if you are very very careful.
I'll add a hanging drop of SuperLube and see if that improves things. I flushed a bit of Goof-Off (nasty blend of light hydrocarbons. And xylene) and that improved things a bit.
A lot of notes and guidance happening on flickr today. For what it's worth, here's a video of getting the shutter to actually set and release, and the gyrations required.
ImageSuper Memar Shutter Cocking Issues by Scott, on Flickr
You have some grease gunked off in the locking arm (10 o'clock)
Goof Off is OK, but either Ronsonol or Electric contact cleaner (Quick Drying), do a much better job
https://www.crcindustries.com/products/ ... 05103.html
This one is safe for plastics and all metals
Apply a few drops (or a good flush), move the levers, clean with a q-tip and repeat a few times
Just saw you lens if pock-marked by fungus?
Your lens is the 2.0 Solagon, does it front-focus or the whole unit moves?
Try cleaning it with a 1:1 solution of 3% Peroxide and cleaning Ammonia (Use in a well ventilated space)
Use gloves as it might discolor your skin and burn a little
You will see it bubbling on the lens, let it stand for a few minutes, rinse well and let dry.
In case anyone missed it on flickr, here's the front glass:
ImageIMG_3240 by Scott, on Flickr
So, the seller offered 30 day free returns, and this one is going back. Bummer.
That's too bad, Scott. Keep looking, you'll find a good one eventually.
That's too bad. That front element is beyond help, unless you're looking for that low-contract not-sharp look.
Look what the postman brought today...
Loading film now... thank you, Mike!! :)
That looks like a typical Synchro-Compur.
I am a big fan of the Konica I, II and III rangefinders. Each is very different.
melek wrote: ↑
Mon Jun 14, 2021 7:59 pm
I like the Konica I too
ImageKonica by Scott, on Flickr
Have pondered selling this camera (my fourth Konica I) many times, but have always ended up keeping it. Joy to use.
