Oops...
Re: Oops...
titrisol wrote: ↑
Tue Mar 16, 2021 1:41 pm
LOL, I sitll have those elements from an Jsolette I've been juggling with for months... no budging yet
If an extended period of heating from a hair dryer doesn't let me separate them, I think I'm investing in these:
Re: Oops...
Maybe that’s gonna be too thick for the job, I bought the XS size when they did very well.
https://www.bhphotovideo.com/c/buy/Othe ... 4026728365
Re: Oops...
I have tried those, I even 3dprinted my own lens wrenches to fit the elements perfectly (If you want the STLs let me know)
I couldn;t find PB Blaster locally, but finally found it last weekend at ACE hardware so I'm soking the elements on that and will see what happens
(sorry for high jacking the thread)
Re: Oops...
I’m not sure if I fully understood, the problem is to separate the two front elements that are threatened, right?
Have you tried to drop so lighter fluid to dissolve the grease? Or any other grease solution.
When I did one Isolette III I remember it was quite solid but I don’t recall I had problems with this part, just patience and lighter fluid did the job.
scott wrote: ↑
Tue Mar 16, 2021 4:59 pm
titrisol wrote: ↑
Re: Oops...
Yes, that is the problem and the AGFA epoxy grease has been treated with lighter fluid, acetone, penetrating oil, and generous applications of heat (dryer)
Lots of green flakes at the beginning but the 2 elements havent budged so far
alexvaras wrote: ↑
Thu Mar 18, 2021 9:39 am
Re: Oops...
Then if it doesn’t come out with these chemicals my next move would be paint stripper applied locally in the thread (only), that would slowly take out layers after layers, slow process but never failed me.
Re: Oops...
I've only once had the Bayer grease not loosen with heat: I had a Super Speedex once (one of two cameras I ever regret selling...). Absolutely could not even budge the helical. Deciding I'd rather invest in the camera than booger it trying something else, I sent it off to Jurgen Kreckel. He got it cleaned and lubed and sent it back. When I asked how he'd gotten it apart, he replied that he has a trained gorilla for just such a situation...
Re: Oops...
I'm a believer!
epatsellis
Re: Oops...
Post by epatsellis »
For future reference, it PB Blaster doesn’t work, AeroKroil is ridiculously expensive but has never failed me.
Re: Oops...
Thanks @epatsellis just did a quick search for it.
Aerokroil is now Kroil Original Penetrant; they were acquired by some private capital last year.
They also have a precision lubricant (Microil) which seems perfect for our purposes
I wish they had a local distributor, $11 for 8oz is expensive, but not so bad.
https://www.kroil.com/where-to-buy/
