I was told by a Zeiss rep that these Yashicas were assembled on the same line as the Contax 137/139/159.PFMcFarland wrote: ↑Fri Oct 20, 2023 11:42 amYashica FX-3 Super 2000
A simple manual camera made by Kyocera, its main feature being the addition of a 1/2000 sec shutter speed. Mine came with the attached 1.7/50 Planar.
Please, PF, what is that adapter with coupled rangefinder? A Planar in the M3 would be really nice.PFMcFarland wrote: ↑Sat Oct 21, 2023 12:52 amI actually have two of these as on the first one the Bulb setting doesn't work. I never really trusted them, the FX-2 being a better built body. I got an adapter the other week to be able to use this lens rangefinder coupled on my M4-P.
Manyu chinese sellers hve 40-40.5 stp up rings at a decent price
E.g. https://www.ebay.com/str/yoyocameraaccessories has it for $8 shipped
It is manufactured by Shoten, and they have an eBay store where you can order them. They are made for only the 50mm focal length of whatever mount it is designed for, and they couple to the Leica M series rangefinder mechanism. So, if the brand of lens mount you order the adapter for has multiple 50mm lenses in different minimum or maximum aperture versions you can use any of those lenses focusing to infinity (they supply a small screwdriver in case you need to adjust the adapter). But you cannot use any other focal length as the design doesn't work on anything other than 50mm. Nothing longer or shorter. If you have a mirrorless camera you can use this adapter along with an M to whatever brand mount (like Nikon Z) your mirrorless camera is. To focus the lens you set it at infinity and use the Summicron style focus tab on the adapter.alexvaras wrote: ↑Tue Nov 07, 2023 4:47 pmPlease, PF, what is that adapter with coupled rangefinder? A Planar in the M3 would be really nice.PFMcFarland wrote: ↑Sat Oct 21, 2023 12:52 amI actually have two of these as on the first one the Bulb setting doesn't work. I never really trusted them, the FX-2 being a better built body. I got an adapter the other week to be able to use this lens rangefinder coupled on my M4-P.
Here is a camera I spent numerous hours on getting it back into working and cosmetic condition, the Univex Mercury II. Half-frame 35mm (65 frames on a 36-exposure roll) with the Universal 35mm 1:2.7 Tricor lens sporting a push-on Kodak Series V adapter ring 1 1/16" (27mm) with a Series V-A hood and yellow Series V filter.
Univex Mercury II Accessories by P F McFarland, on Flickr
That Mercury is an interesting camera. I like the exposure computer in the back.
The only problem with it is the older my eyes get, the harder it is to use it. It is however the most accurate Sunny-16 scale metering gauge I've ever seen. Someone should market a copy of it for all of us die-hard old camera users.
Interesting… have you tried it? Was it difficult to adjust?PFMcFarland wrote: ↑Thu Nov 09, 2023 1:50 pmIt is manufactured by Shoten, and they have an eBay store where you can order them. They are made for only the 50mm focal length of whatever mount it is designed for, and they couple to the Leica M series rangefinder mechanism. So, if the brand of lens mount you order the adapter for has multiple 50mm lenses in different minimum or maximum aperture versions you can use any of those lenses focusing to infinity (they supply a small screwdriver in case you need to adjust the adapter). But you cannot use any other focal length as the design doesn't work on anything other than 50mm. Nothing longer or shorter. If you have a mirrorless camera you can use this adapter along with an M to whatever brand mount (like Nikon Z) your mirrorless camera is. To focus the lens you set it at infinity and use the Summicron style focus tab on the adapter.alexvaras wrote: ↑Tue Nov 07, 2023 4:47 pmPlease, PF, what is that adapter with coupled rangefinder? A Planar in the M3 would be really nice.PFMcFarland wrote: ↑Sat Oct 21, 2023 12:52 am
Found this in Photrio: https://www.photrio.com/forum/threads/f ... slr.79561/PFMcFarland wrote: ↑Fri Oct 20, 2023 11:42 amYashica FX-3 Super 2000
Yashica FX-3 Super 2000 by P F McFarland, on Flickr
Thanks, Pablo. Too bad the photos are no longer available for most of that thread, but then again I have no intention of working on either of my FX-3's.titrisol wrote: ↑Sun Nov 19, 2023 11:28 amFound this in Photrio: https://www.photrio.com/forum/threads/f ... slr.79561/PFMcFarland wrote: ↑Fri Oct 20, 2023 11:42 amYashica FX-3 Super 2000
