Zorki-1D replacement check-out
Went to Fincastle, VA to test out my replacement for the worn out Zorki-1D I bought seven years ago. It has been overhauled, and works just fine with the I-22 lens from the old camera. The rangefinder is spot on, and the shutter is good too. Just a few occurrences of light leakage from around the base plate, which should be easy to fix. For the most part, exposures were good, which indicates consistency in the camera functions, and I’m getting better at Sunny-16.
For some reason, this came out better in landscape than it did in portrait.
Old Fincastle Jail 2 by P F McFarland, on Flickr
Yes, the I-22 will flare a bit. Not bad though, considering this is after I cleaned it.
Old Fincastle Jail 3 by P F McFarland, on Flickr
As luck would have it…
CCCP by P F McFarland, on Flickr
Just a slight contrast adjustment to better show the clouds.
Chapel Spire by P F McFarland, on Flickr
See all 16 photos with full commentary at https://flic.kr/s/aHsm4XAvSE
Re: Zorki-1D replacement check-out
That CCCP shot is a great one. I wonder how you can get a leak in the bottom plate!
The lens is a good performer, I like the "flowery path" picture.
Julio1fer wrote:That CCCP shot is a great one. I wonder how you can get a leak in the bottom plate!
I wonder too, Julio. But then it is a Zorki.
