Page 2 of 2
Re: More from my monochrome archive
Posted: Tue Apr 27, 2021 9:53 am
by titrisol
alexvaras wrote: ↑
Tue Apr 27, 2021 12:33 am
I tried with IPad myself, maybe it was old version when I tried or the setup was bad... I could see the illuminated pixels, white light was not homogeneous.
I used an old GEPE cold panel, and went it started to go bad I got a LED panel from Amazon
Light was in "lines" so I put some drafting paper on top of it and separated the neg from the light about 3cm and it worked fine
I guess a small piece of white or frosty plexiglass would work better
I also designed a carrier for my camera on the enlarger column to maintain the parallelism between sensor and negative (based on the old Nikon copy stands)
It is customized for my camera and enlarger but can be easily adapted for any camera.
ImageRepro-Copy Adapter for Pentax
Posted: Tue Apr 27, 2021 11:26 am
by GrahamS
Basically what I have, just made of different parts.
Posted: Wed Apr 28, 2021 7:41 pm
Been thinking of a digitizing outfit myself, Graham. It's why I got the D610 so I can use the Nikon made adapter that fits on the 60mm macro.
Posted: Thu Apr 29, 2021 5:40 am
by GrahamS
PFMcFarland wrote: ↑
Phil, which 60mm macro is that?
Posted: Fri Apr 30, 2021 2:17 pm
GrahamS wrote: ↑
That would be the ES2 adapter on the AF Micro Nikkor 60mm 1:2.8D, Graham.
Posted: Fri Apr 30, 2021 4:39 pm
by GrahamS
GrahamS wrote: ↑
Nice lens. Dennis Gallus uses one to great effect.
Posted: Sat May 01, 2021 12:58 am
GrahamS wrote: ↑
GrahamS wrote: ↑
The ES-2 is also compatible with the G series 60mm micro, and the DX 40mm micro.
Posted: Sat May 01, 2021 8:00 am
by GrahamS
GrahamS wrote: ↑
Only problem is that it will only accommodate 35mm positives or negs. I do a lot of MF.
