Yashica Electro 35 MC Twins
No focusing assistance included. Take your best guess.
Yashica Electro 35 MC Twins by P F McFarland, on Flickr
Got really lucky on an auction one night, and won a two-for-one deal on these cameras. Turns out one was made in Hong Kong, and the other in Japan. You can only tell the difference between the two by the manufacture stamping on the base plate, the serial numbers (the Hong Kong model starts with an H), and the name ring on the lens (the Hong Kong model says “Lens Made In Japan”, while the other one says “Yashica Japan”).
40mm f2.8 lens, step less shutter speeds electronically controlled from 4 seconds to 1/500. X-Sync automatically set when a PC flash cord is plugged into the socket, with GN setting scale on the lens barrel. Viewfinder with Focus Zone indicator (scale focusing on lens), and bright line frame with parallax marks. Battery Indicator lamp on top stays on during exposure or self timer actuation.
Just a nice, compact camera that would be great for street photography.
It didn’t burn out the highlights
High Contrast Check by P F McFarland, on Flickr
I should have chosen something with a darker background
Close-up by P F McFarland, on Flickr
A touch of flare
Backlighting by P F McFarland, on Flickr
F2.8 on the left, and f16 on the right
Depth-Of-Field by P F McFarland, on Flickr
Between 2-3 seconds at f2.8
Night Tower by P F McFarland, on Flickr
The second roll, Kodak Ektra 100 in the “Made In Japan” model, was all over the place as far as exposures were concerned. It did seem to settle down after a while, so it could just be the shutter working out some stiffness after who knows how long it’s been sitting around.
Needed a little exposure adjustment (slightly dark)
Water Veil by P F McFarland, on Flickr
Exposure and focus good on this one
Dancing Tree by P F McFarland, on Flickr
Strong backlighting
Autumn Holdouts by P F McFarland, on Flickr
And bring up the rear of this camera test
Rounding The Point by P F McFarland, on Flickr
To see all the examples, follow this link to Flickr https://flic.kr/s/aHskx55FvJ
Re: Yashica Electro 35 MC Twins
The B&W series looks pretty good and the lenses are sharp. A capable pair of little compacts.
So, they have no manual control for exposure? you just set the aperture and go?
Julio1fer wrote:The B&W series looks pretty good and the lenses are sharp. A capable pair of little compacts.
That's pretty much the jist of it, Julio, Aperture Priority only. You can do daylight fill flash, though the sync speed is 1/30.
That is good enough for a lot of work, PF. You got a lucky pair of twins.
These are nice little cameras indeed and there's not much on them that can break. I really like the style of this model : it looks less dated than the GSN, perhaps because of the more square angles. The aperture priority seems to work great, and you got some very good results there from them.
