Rollei A110
For those who still use 828, 126 Instamatic, 110, 16mm and Japanese HIT cameras and other sub-miniature formats.
Will
Rollei A110
Post by Will »
Does anyone know if the film door opens mechanically or electronically? I cannot open the door but it has no battery yet so I cant tell.
Re: Rollei A110
The film door opens mechanically.
Slide the camera open and turn it upside down. You'll see a drawing of a 110 film cartridge. Press on the orange part of the drawing near the sliding portion and pull outward. The door will flip open.
The battery is a PX27 5.6-volt. The replace is 6 volts, which should be close enough.
Will
Re: Rollei A110
Post by Will »
I do understand but I cannot open the door with the battery not in place
Re: Rollei A110
I've recorded a short video showing how to open the camera. It doesn't matter if there is a battery in the camera.
If you cannot open the film door, then there might be a problem with the camera.
[video]http://youtu.be/fd8F2VkARLY[/video]
Re: Rollei A110
Mike, your video makes it look positively simple! Thanks. I must dig mine out from a cupboard somewhere. I had my A110 for several years before I filed it away as unusable because I could not find the battery compartment. Now I know. :)
