A tale of two F2S's
A tale of two F2S's
To put it mildly, I have diverted from the path I set out on many years ago in gear acquisition to the detriment of my Nikon gear not getting enough use. I'm over that now, but I hope it explains why so much time can elapse from the point of purchase to actual use.
I've had a black F2S for many years now. It was always my dream camera, and I figured I'd probably never get another one. I mean, it worked fine, so why bother? Well, last year I was in my favorite junktique store, and there was an F2S in chrome for $60. It looked to be a low mileage model, as the body had no marks on it, and the meter head had what could be described as handling marks, considering how it was part of an estate sale, and who knows what kind of box it may have been stuffed in for transfer to the store. The Series E 1.8/50 on the front was kind of a let down, but it was in good shape, and I needed one for my EM anyway.
Now when the advance lever was pulled out, the meter did not activate. Eh, no problem, either the battery is dead, or missing I figured. Besides, it can still be used like it had an eye level prism installed. I get it home, and sure enough there is no battery, so I cleaned off the contacts, and installed a 3v lithium. No lights!
I tried several times to get the meter to activate. I switched the head to the black body, and it was a no go. I put the head from the black body on the chrome one, and it worked, so that showed power to the meter head. I put the heads back on their respective bodies, and set the chrome one back for later work.
Fast forward to yesterday. I had done some rearranging around the apartment, and when I came across the dead F2S I set it out where I could see it so that it would get me to do something with it. Saturday was that day. I again took the head off, cleaned all the contacts, put in a pair of 357's that I use to test out various pieces of equipment, and still nothing.
So last night just before going to bed I once more put the camera through its paces. Suddenly the meter came on! It wasn't right away, more like about ten seconds after I pulled the advance lever out from the body to activate the meter switch. I kept turning it off and on, and the times between pulling the lever and meter activation started to get shorter. Then one time it sort of flickered quite a bit, but the next time came on good and strong. I switched out the 357's for a fresh 3v lithium, and the meter start became instantaneous. Man, I was so happy when my head finally hit the pillow a short while later.
Got up this morning, and checked the camera operation, and it was still working good. Haven't taken it out yet to see how accurate it is against a good meter, but it passes the desk lamp test I do where I set the ISO to 125, and point it to the lamp from a foot away, then see what aperture it settles on. f5.6 is the target, and that's where it was. Which is good because I had perused the auction site to see what DP-12's were going for, and found it was cheaper to get another camera with that head, though still an expensive proposition. I didn't want to wind up with another body, so I'm happy this one came back to life, especially since it has the P screen, and I didn't want to be swapping prisms and screens every time I wanted to switch which F2 body I was going to use. I likely would have just gotten another DP-2 in case things didn't work out.
So I was wondering if any of you have had a similar experience with your DP-2. My take on the whole thing is there is a capacitor in the circuit that, like in a flash unit, will "dry out" from non-use, and needs to be rejuvenated by putting in fresh batteries and turning the unit on until the ready light appears (may take hours or days). I'll have to find a meter circuit to see if that could be true. One other possibility is the activation of the lever to the lens prong (by working the aperture control ring back and forth) may have cleaned the wipers inside the meter head so the circuit could be completed. Third possibility is a combination of the two.
Whatever it was, I'm pleased that I now have two F2S's in working order (though the chrome one could use a new set of seals). They should both be getting more exercise now, along with me.
Nikon F2S Chrome by P F McFarland, on Flickr
Nikon F2S by P F McFarland, on Flickr
Re: A tale of two F2S's
Perseverance paid off! Glad to hear it works and you have a backup. Happy shooting!
F2 is a great body. Glad that you got the meter working, electricity is always a deep mistery. I'd bet more on contacts than on capacitors.
Congratulations. Being completely unhandy, the *only* time anything of mine ever gets fixed is when, like yours, it somehow and mysteriously fixes itself!
Great story with a happy ending. I'm an F2 fan myself and love my chrome F2AS, although it would appreciate some more use from my side.
My other F2, a black body with DP-1 head that I purchased rather cheaply from the auction site had a jumpy meter needle, which disappeared after cleaning the carbon(?) track in the resistor ring inside the metering head. That body had a dimple in the front of the top plate, and being a bit of a maniac I sold that camera again.
Some of my Nikkormats also had jumpy meter needles, which is cured by moving the shutter speed ring, as well as the metering prong back and forth a number of times. Sometimes those Nikkormat meters become jumpy again after a while of sitting idle in my camera cabinet. So I'm thinking it could mainly be oxidation of the resistors?
Your tale looks indeed like resistor trouble - dirt, surface oxidation or drying lubricants, or maybe abrasion wear of the contact track. As I understand it, carbon strips do not oxydize but metal contacts do (that's why sometimes contacts are gold plated).
Quite a suspense story with that second F2S! But it turned out well. Beautiful pair of cameras. How about that AF zoom that you got with the N80? Does it work (easily) with the F2S?
Julio1fer wrote:Your tale looks indeed like resistor trouble - dirt, surface oxidation or drying lubricants, or maybe abrasion wear of the contact track. As I understand it, carbon strips do not oxydize but metal contacts do (that's why sometimes contacts are gold plated).
I don't know, Julio. The fact that the meter came on a few seconds after the switch had been thrown leads me to think capacitor problems, and that the delay became shorter as time went on. I wasn't moving anything when the lights finally showed up.
minoly wrote:Quite a suspense story with that second F2S! But it turned out well. Beautiful pair of cameras. How about that AF zoom that you got with the N80? Does it work (easily) with the F2S?
I haven't thought to try that, Bill.
Captain Slack
Post by Captain Slack »
Could be a cap that needed reviving or it could be a loose connection some place. If it's stops working again after some use, that's where I'd start investigating.
