First roll in the Canon F1
First roll in the Canon F1 that I purchased, well... a few years ago. I thought it was about time that I put a roll through this camera.
I am more a Nikon user, but I quite like this F1.
The lens is the Canon FD 50mm F/1.4 S.S.C. and the film was an Agfa APX100 24exp, of which I still have quite a few rolls in the freezer.
Developed this morning in 10 years old HC-110 (Dil.B) for 7 minutes. I think the images are a bit too contrasty, and only this one is more or less worth showing, the others being too harsh. It was just after noon and the sunlight may have been a bit too strong.
Re: First roll in the Canon F1
That's a good combo, Benny. I take it that is the original version of the F1.
Less agitation, not less time, Benny. The F1 is a nice camera.
Good instruments, that Canon combo is probably a good match for your Nikons.
That is a nice cows portrait.
I loved APX 100. It does go high in contrast quite easily. I used it with Rodinal and have no experience with HC-110, but you will get less contrast with shorter times or more dilution. Less agitation could also help. If you can use a two-bath formula such as Diafine it would also do a lot of compensation for harsh lighting. My favorite for these situations is Beutler.
Thanks guys for the good tips.
The dilution was 1:31 ('Dil.B') and I reversed the tank 5-6 times every 30 seconds or so, like I usually do with Ilford HP5 film.
Maybe that was too much here, but I figured that less agitation would not be enough given the age of my stock solution. This proves however that old HC-110 is still as good as new. Come to think of it, it's about twelve years old and by now the color is a deep brownish orange, but still transparent. I had bought a new bottle last month because I planned to dump the old one, but I can see now that this would be a shame. Perhaps I just need to shoot more film :-)
Indeed Phil, I have the first (mechanical) version of the F1. Here is a picture of it. At first I was not too wild about the 'circle and needle' meter indication in the viewfinder, but it grows upon you after a while.
Just to show how hard the negatives are, here is one of the same roll with minor tweaking in PSE : reduced contrast and slight darkening of the highlights.
I like both of them Benny, I can see all the range in both photos and the tone is super nice.
I like the bell with the modern sign to ring on the second photo :)
Now you're cookin' with gas....
Thanks Graham.
Alex, yes I too thought that was funny. That gate and the little old bell are at least 50 meters away from the (now abandoned) house. I wonder if they could here it when someone called...
Try it, you could be surprised:)
