Koilos shutter fixing and cleaning.
Here its something 100 years old at least, it has a Tessar SN#123452 from 1909/1910.
The shutter doesn't stay cocked.
Some photos here, all of them in flickr.
It was due dirty grease and a bit worn out, lets see if tomorrow it keeps working :)
https://flic.kr/s/aHsmsxc25a
Thank you for watching.
Re: Koilos shutter fixing and cleaning.
Alex, nice work on that shutter. The fact that such an old shutter can still work correctly after more than 100 years. It says a lot about the design, precision and choice of materials that went into the manufacturing process.
I like the way they coded the shutter blades with the little holes. Good job on the clean out, Alex.
Arthur Dent
Post by Arthur Dent »
Hi,
Apologies if this is a newbie question. but...
How did you remove the circular cap from the cam/latch of the shutter lever (between pictures 5 and 6 above, my picture attached). I have tried a few things but don't want to force it. Speaking with a clock repair specialist, he though it might be braised.
With thanks,
AD
Welcome to the forum!
I would say it’s screwed.
All these rounded parts with two holes are usually screwed.
Have you tried one drop of acetone and try again?
It’s late already here but tomorrow I should be able to take a look to my shutter, still with me that lens.
PS: no question is newbie.
It’s a usual CCW thread.
It was a bit tight and the cocking lever was moving along so I had to put my thumb on it meanwhile I was using pliers to turn the rounded piece out.
Arthur Dent
Thanks Alex,
I assumed with the 2 holes on top it would unscrew but didn't want to force it with a lens wrench just in case.
Very grateful for your help,
Jim
Nice work on the shutter!
I like it when the shutter blades are screwed into the housing.
You are welcome, Jim.
Mike, yes, it’s always a pleasure not watching them jumping around :)
Good to have such a knowledgeable member like Alex here. Thanks for the informative pics, Alex. It's always nice to study the innards of shutters and cameras and realise that there is no way I could ever even start thinking about diving into that myself :-)
