What did happen here? vol.2
Posted: Sun Feb 24, 2019 10:37 am
And now with the Contax IIa.
We had some activities in the school on Friday and I had a roll loaded on the camera that I finished outside, all ok, I loaded a color Fuji C200 I had at home and 4 first frames were ok: At fifth this started to happen: This big and lower lines started to move a bit up and down but mainly in the upper part of the photo.
About 25 photos have this but when I can inside the building the line disappeared: I finished the roll inside, should I check anything on the camera? As I said the previous BW film went ok.
Mike or anyone with Contax and collapsible lenses, could it happened I didn't opened correctly the Sonnar collapsible? I say this because probably I closed the lens going inside the building the opening back again inside.
The film was processed on a lab.
Thank you in advance,
