Good News/Bad News
Posted: Thu Jul 09, 2020 6:42 pm
Good news: The new 18x24cm holders arrived from Sweden!
18x24cm DDS’s by Scott, on Flickr
Set up a test today. I'd made modifications to the loading end springs on the back, seems tight enough. Set up a closeup of the Konica, more than 1:1 on the 18x24 UM-MA. 20" of draw with a 5" lens. Guessed at reciprocity compensation, got in the ballpark.
Konica by Scott, on Flickr
So, the bad news: The holder seems to have a small leak on the slide end. Not sure what to do about that. Need to try the other side, and other holder. Hopefully the rest are better.
18x24cm DDS’s by Scott, on FlickrSet up a test today. I'd made modifications to the loading end springs on the back, seems tight enough. Set up a closeup of the Konica, more than 1:1 on the 18x24 UM-MA. 20" of draw with a 5" lens. Guessed at reciprocity compensation, got in the ballpark.
Konica by Scott, on FlickrSo, the bad news: The holder seems to have a small leak on the slide end. Not sure what to do about that. Need to try the other side, and other holder. Hopefully the rest are better.
