Page 1 of 2
Hanimex 35SL showed up...
Posted: Thu Dec 11, 2025 12:04 pm
by scott
Howdy all -
My brother is trying to downsize these days; when we were down there for my dad's 85th last summer, he asked if I wanted any of dad's old camera gear. All 135 stuff, and a lot of it in kits I have no accessories/lenses for. However, there was a Hanimex 35SL in there that seemed in good shape. M42, and I have a ton of that stuff. Sure - send that up, please.
Happened to arrive both on my birthday and while I was in recovery. Turns out it's pretty much an entire kit:
Pretty much a straight-up Spottie clone. Camera works fine. Haven't been able to test the meter, though I suspect that is defunct (though, the meter on my Spotmatic works just fine). Thee are four lenses, a 3x TC, a branded Hanimex flash, some other flash two cases, and a handheld meter. Was not expecting that.
Hopefully will be ambulatory enough in short order that I can hobble around some little local town and run off some film. Guessing the seals are likely shot, too, but looks like a fun little camera.
Re: Hanimex 35SL showed up...
Posted: Thu Dec 11, 2025 11:40 pm
Yeah, you'll need to be in good shape to haul all that glass around. Heal up, and Happy Birthday!
Posted: Fri Dec 12, 2025 12:28 pm
by scott
Thanks, PF! On all counts. None of this stuff gets any love online, but I grew up seeing the pictures my dad took with them, so I'm optimistic. And, have all the Super Tak stuff as well. Looking forward to playing with it!
Posted: Fri Dec 12, 2025 8:37 pm
I do believe there are some Hanimex items in amongst all my photo gear. I know where to send it now when I come across it.
Posted: Sat Dec 13, 2025 11:48 am
by scott
Lol, I would be honored, PF!
My Spottie accepts a 312 battery and the offset is generally covered by the latitude of the films I use. So I was hoping this 35SL would also take a 312. It does not. Typical mercury battery, as everything back then did. However, somehow, dad had a spare, unwrapped mercury battery in the case that does, in fact, work. Dunno. But the meter is fully functional. And, there's a Super Pilot SBC in there, too. He left batteries in everything, so I need to clean out corrosion and find those adapter batteries for it (if I decide to use it at all). Neat stash.
Throwing some Arista 200 in it now so I can try it out once I'm hobbling around again.
Posted: Sun Dec 14, 2025 12:28 pm
If it is indeed a clone of a Spotmatic, the metering circuit is a bridge type. Should work OK with an alkaline battery of the same size as the original mercury battery. And get well soon!
Posted: Tue Dec 16, 2025 2:58 pm
by titrisol
Looks more like a Chinon or Praktika than an Asahi, I dont think it will work with Silver batteries unless you adjust the circuit
Posted: Tue Dec 16, 2025 6:10 pm
by scott
Yeah, it’s apparently a rebranded Chinon 35CS. Operably, functionally, and compatibility wise, same same, but different. For now the meter is working with the random mercury battery that was floating in the case. Not a right now problem, lol.
Posted: Wed Dec 17, 2025 7:58 am
by titrisol
scott wrote: ↑
I bought a Japanese MR9 (Kanto) adapter for the Yashicamat 124G, it worked great
Posted: Thu Dec 18, 2025 12:50 am
Yep, every source I could find says Chinon CS. You could get a Wein cell to replace the mercury one, but none of the specifications I read included what size the battery is, just that it is 1.35v which means it's either a PX625 or PX675. The 625 is the larger of the two, while the 675 is about the size of a 375 alkaline or SR44 Silver Oxide. You wouldn't need an adapter with the Wein cells, but they don't last very long, about 3 months at the most.
