Adjusting the RF in a Karat 36
I followed the C.Sherlock videos to get this camera back to life.
However when I put the top together I needed to readjust the RF.
The RF unit was taken out to clean and lubricate the film transport/winding mechanism and is held by 3 screws (marked in yellow)
Under the top of Karat 36v3 RF unit out
I looked at the unit and it was focused at infinity by default, and has a small pin/tab at the bottom that moves one of the sided for close focusing, and a spring returns it to infinity. Mine was sluggish to return and I cleaned the rail with a qtip moist in electrical contact cleaner (green Agfa goo).
Bottom of RF unit
Bottom of RF unit
When focusing a lever moves and pushes the pin, so after assembling I left the screws loose, and moved the RF unit horizontally (L-R) I got infinity right. Confirmed with 2m(6ft) and 5m(15ft) looking at a bookcase.
Re: Adjusting the RF in a Karat 36
Thanks for posting this. I just brought my Karat 36 up from the basement with the intent of working on it, including the rangefinder.
I've found some of the Agfa rangefinder units to be average, and adjusting them to be a finicky process that might hold - or might not.
I didn't touch the unit itself, it was self contained
I looked through it and it was well focused to infinity, so that was a win
Then I tried to figure out how it worked and how it coupled, and from there it was clear that this adjustment wasn't too bad.
Alex gave me some pointers on how to clean the mechanism, and suggested to lubricate it with graphite
I was thinking on using a drop of blue threadlock in those holding screws but the amount of force exerted by the RF coupling is minimal
If this was out of whack I think you can adjust infinity by the screw on top of the one marked with the yellow +
Vertical adjustment would be a bear though
IN the next Karat I opened I marked the location of the RF unit with a sharpie to make reassembly easier. (ghetto way)
Chris's videos are excellent. They gave me the confidence to fix several cameras recently.
While working on a Karomat I made the mistake of removing the big brass screw that holds the RF-lever
It can come lose over time, so remember to add threadlocker to it during reassembly
I added some notes to supplement PFM pictures
https://flic.kr/s/aHBqjC9N8i
I admit I have a problem!
Clockwise from bottom-right
Karat 12 Xenar
Karat 36 Xenar
Karat 36 Heligon
Karomat Xenar
Karomat Solinar
That is a nice collection, not a problem!
Sometimes we can learn good tips from our kids!!!
MY daughter saw me on my 4s looking for a spring with a magnet, took me a good 45 min until I found it.
She said "Dad, I saw this life hack" just use some string to handle the springs and you will see them easily.
I'll be darned, it worked!
Not only it was easy to see if it flew, but made the install simpler and more efficient
Good tip!
Nice collection of Karat cameras. I'm getting ready to do a video on the Agfa Karat, so it required me to buy more Karat models. I've been wanting to get a couple of cameras with the Rodenstock Heligon. I did find a Retina IIc (small c), which is another camera in line to be serviced and put to use.
titrisol wrote: ↑
Fri May 02, 2025 4:05 pm
Karat 12 Xenar
Karat 36 Xenar
Karat 36 Heligon
Karomat Xenar
Karomat Solinar
