HELP! With the new software!
'The F Stops Here' - What's New, plus comments and questions about the forums.
Re: HELP! With the new software!
Geez, through all of this everything has worked fine for me. Maybe I have been logging in at just the right times.
--- James
BillyBob
Post by BillyBob »
Works now!
Thanks Mike!
Bill
AdminPTF
Post by AdminPTF »
jamesmck wrote:Geez, through all of this everything has worked fine for me. Maybe I have been logging in at just the right times.
--- James
I think you need to play the PowerBall with that much luck! :)
OpenWater
Post by OpenWater »
I did as Mike's email suggested (delete browser cookies for this site and delete board cookies) and everything seems to be working OK. Just to check though... The site nows shows a medium blue header bar with lighter blue toolbars below - no photo like the login page. If this is the current build, then everything is OK.
Update: I just played around with the user control panel. we_universal turns on the photo with other options also available. Everything seems to be working fine.
OpenWater wrote:I did as Mike's email suggested (delete browser cookies for this site and delete board cookies) and everything seems to be working OK. Just to check though... The site nows shows a medium blue header bar with lighter blue toolbars below - no photo like the login page. If this is the current build, then everything is OK.
Try reloading the page.
If that doesn't work, go to your "User Control Panel" and then "Board Preferences" and change to "we_universal" or any of the other styles.
OpenWater
Post by OpenWater »
Yup. Modifying the Board Preferences does the trick.
AdminPTF
Post by AdminPTF »
If everyone seems to be up and running correctly, I probably will remove this discussion or possibly hide it.
Keep it going. CE used to do that and then we would ask the same questions over and over.
AdminPTF
Post by AdminPTF »
OK, fair enough. It lives! :o
