Playing with the Spottie...
Hi, all -
A few weeks ago I sniped into a Super Takumar 50/1.4, not too badly yellowed by the Thorium. I was waffling between bringing the Spotmatic or a Canon L3 (or P) on our trip to Cali later this year. For many reasons opted for buying a lens for the Spottie. I bleached out most of the yellow under a high intensity LED for a few days, loaded the camera with Kentmere 100 and shot some pictures. Mostly test stuff, but the back half of the roll was on a couple walks at the Hill School with one kid then t'other. Those turned out better, and I present them here.
The camera is too much fun to use, and I'd forgotten how nice it is to play with small cameras. Scanning wasn't all bad, either, though a roll of 6x6 is a lot nicer to do than 36 little tiny frames. I'm not sure I like the Kentmere - seems awfully grainy for 100, but that might be the Adonal or the scanning, not sure. I have a roll of Acros in the camera now to see if there's a difference. The lens is wonderful.
So, I'm on the fence: Either take the Spotmatic on our wine country trip with the 50/1.4 and my 35/3.5, or bring along some version of a 6x6 (either the Bronica which seems like it would be overkill, or the Yashica-Mat, which hasn't been used in AGES). Regardless, I need to play with this camera, and all the others, a lot more than I have been lately.
Thanks for looking.
Re: Playing with the Spottie...
All nice and crisp, Scott. Love the closeup of Maddie and the ram.
Great shots of the kids at Hill School, Scott. Makes for some interesting backgrounds, and you haven't lost your touch on 35mm. Just like riding a bike.
For your traipse through the vineyards, the Bronica might be overkill, but you'd slay it with that rig. Since your Yashica-Mat has been sitting for so long, it might need a bit of a cleaning before working properly. Could be time consuming on the run-up to the trip. You'll be in wine country, where it's all about vintage, and you can't get much more classic vintage than a Spotmatic. Plus, it weighs less than either of the other choices. Don't forget to take a flash unit.
Thanks, James and PF.
PF, there are pros and cons on all of them. The Yashica-Mat has been idle a long time, but I tested it out and the overhaul I gave it is still good. Everything works precisely. It's loaded with Acros right now. The Bronica is a beast, but is probably the nicest medium format I've ever used, and even the S-grade lens is spectacular (though I'd probably try to find a bottom-feeder 80 PS for the trip). It is also loaded with Acros. The Spotmatic is by far the easiest, lightest, and most adaptable of the three. Just don't know as I want to deal with 135. Again, currently loaded with Acros (seeing a trend here?). I have a while to decide; I think it will require shooting all three a bit to confirm...
Well, whatever you choose, I'm sure you'll come back with some spectacular images.
